93 blazer idle rough and hard time starting
Old Feb 19, 2010 | 07:02 PM
93_blazer's Avatar
93_blazer is on a distinguished road
The fuel pressure is good, it is at 58-60 PSI, i replace the PCV and that did not seem to do anything, the car still idle rough with the new ignition control module, hopefully this fix the starting problem. there is no engine code. i took the EGR off today but i am not sure how to tell if its bad or not, any idea? the little plug with the hex key seems to push in and spring back to place, is this normal? i will take the spark plugs out this weekend if i have time. here is what i have done so far:
Plugs (1 year old)
Wires (1 year old)
Cap (1 year old)
Rotor
FPR
Fuel Filter
Ignition Coil
ignition contol module
PCV valve
Vaccum hoses
am i missing anything obvious, running out of ideas.
Old Feb 20, 2010 | 04:27 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Look at your EGR cavity when you pull the valve. Mine was absolutely 100% filled with carbon and rock hard. Tiik a bunch of carb cleaner and even a chisel to get that stuff out. Cleaning the EGR valve is never a bad idea anyway. Some Berryman's works pretty good or pretty much your cleaner of choice. When you put it back on try to get a screened gasket. It will keep chunks from getting blown into it.
Have you checked for vacuum leaks?
Old Jan 28, 2011 | 11:21 PM
dncspencer's Avatar
dncspencer is on a distinguished road
Default 93 blazer
I had the same problem what i did to fix was after changeing damn near everything you would think it was and it didn't fix the problem. i took it to 5 diffrent shops they couldn't fix it either. But i found out what it was and it was the (pick up coil) it only cost $20 and took 5 mins to replace it sit right under the distribitor cap. I changed it and haven't had the problem since. I hope this helps you.
Zach8846
Mar 11, 2014 10:43 AM
blazerprobs
Mar 18, 2012 08:46 PM
ericthughes
Dec 19, 2010 07:00 PM
akiyamatr7
May 20, 2010 12:29 AM
HaRt
Jun 12, 2005 04:15 PM
