93 Blazer - Push Button 4 Wheel Drive
Old Aug 30, 2010 | 04:26 PM
93blazertahoe's Avatar
93blazertahoe is on a distinguished road
Default 93 Blazer - Push Button 4 Wheel Drive
Just got a 93 Blazer with push button 4 wheel drive. I am not use to push button 4 wheel drive. The switch has two settings - one for high and one for low. So what about off? What's the process for switching out of 4x4 to 2 wheel drive?
Old Aug 30, 2010 | 05:15 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
push 4hi to engage push again to return to 2wd, for 4lo you need to be in park or neutral and not moving to engage or disengage
Old Aug 30, 2010 | 06:50 PM
Thanks for the reply. For some reason mine doesn't wanted to disengage from 4hi. I have to turn the car off and then hit 4hi again to get it to switch back to 2wd. Is this a common problem with a 93 Blazer?
Old Aug 31, 2010 | 08:13 AM
Magmotor's Avatar
Magmotor is on a distinguished road
I have the same year, same setup, so far, knock on wood, no problem with mine. The owner's manual goes pretty in depth on the switching in-out, to from, back & forth etc etc...bottom line it says if your having any problems with any of these the "Electronic Transfer Switch" needs adjustment....how the heck you do this I don't have a clue...perhaps someone who does could chime in and let us know....
mirrorimij
Jun 8, 2019 03:34 PM
buggyblazer
14
Dec 23, 2008 08:22 PM
88jimmah
21
Jan 8, 2008 01:37 AM
cwiththehad
Aug 4, 2007 12:00 PM
trudynosports
Sep 29, 2005 12:36 PM
