93 CPI, with a fuel problem, please help!
Old Jun 25, 2011 | 12:48 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
Here it is Saturday, finally have some free time to work on Jimmy. Well, good news is everything under the plenum is fine. Regulator, Injector, nut kit and all of that is fine, even the electrical connector. I borrowed a fuel pressure gauge, but it leaks. So what I did was to turn the key on, and activate the injector with a set of jumper wires from the battery. I could hear it clicking, but no fuel was coming out of any of the poppets. This tells me that either all my poppets are clogged shut(which I doubt) or O'reily auto parts sold me a fuel pump that doesn't build enough pressure. I have a couple more things to check before I drop the tank again. Yay.
Old Jun 25, 2011 | 12:53 PM
Man, I'm so frustrated with Jimmy! I think I will take an extra anti depressant and a short nap before I try and work on the truck. Yeah, thats what I'm going to do. See you guys when I wake up.
Old Jun 25, 2011 | 05:08 PM
Do you want to put another aftermarket pump in? I understand the warranty and all, but what if it happens again. Aftermarket pumps are not known for their quality in this application.
Old Jun 25, 2011 | 09:50 PM
Well, let this post serve as my testamonial that my brand new Airtex pump is junk. I'm going to get my money back and pay the difference for a ac delco or delphi. I'm going to do that tomorrow. I'm going to spend the rest of tonight sulking and getting fat, as is my option as an old man.
Old Jun 27, 2011 | 01:28 AM
Cidium's Avatar
Cidium is on a distinguished road
Sorry to hear about your problems. If you do a search on Ebay you can find a complete ACDelco pump kits for around 65 bucks, that's what I bought. The kit comes with new electrical connector (if needed), sending assembly to tank O-ring, hose bits and filter sock. With that said, you should still get a fuel pressure gauge and test your system, either at the pump or the nut kit. Testing at the pump should give a good idea if the pump is operating at spec, pressure and leak down. I know it's hard to get to the flex lines above the tank so you could always test the pump before the fuel filter with a gauge and the right parts. If you do take the pump out check the O-rings where the flex lines connect to the hard lines of the sending assembly, they do get hard and brittle, even fall out.
Old Jun 27, 2011 | 10:05 AM
I went back to Oreily auto and returned the airtex pump and purchased the Delphi pump. Lo and behold, the truck starts! Alas, there is a new problem with Jimmy. I have a wicked knocking coming from the engine. I think the previous owner knew a little more than he said when he sold us this truck for $700.00. Oh well, it's our baby now. Starting a new thread: Oil pan removal on a 1st Gen 4x4 with a 4.3"W"
Thank you again everyone for all the advice and tips on my fuel problem. I learned a lot. Now, please help me out on my new thread.
cammed93
Jul 27, 2013 04:05 PM
prbjeepin
Apr 8, 2013 10:14 PM
ohsofly
14
Jan 31, 2010 04:41 PM
Confuused69
Aug 2, 2009 11:53 PM
rogggg1020
Nov 11, 2008 08:05 AM
