93 s10 Blend door actuator bad?
My ac hasn't worked in years so I replaced just about everything under the hood ac related. I came to find the air will only blow out of the defrosters and the floor vent, and its not cold air. There are 2 blend door actuators down under the dash near the floor on the driver side. Any one know which needs to be replaced?
Sorry...I got distracted before I finished. The first thing you want to do is make sure you have vacuum to the controls
Here's a link to a parts book
compnine
Scroll down
compnine
Scroll down
+1 on the vacuum check. The default position of the doors is such that you'll get some air out of the defrost ducts & some out of the floor ducts when there is a complete loss of vacuum to the HVAC system.
Good call on the vacuum check. I found a leak in the vacuum line to the transmission/transfer case, not sure which one it is. So i just capped it off and everything works fine now. Thats probably why my over drive doesn't work I can see inside all 3 vacuum lines that run along the transmission.
On a '93 you shouldn't have a vacuum-controlled transmission. Those vacuum lines go to the transfer case. If you do a search on this forum you can find information about how the vacuum lines control the transfer case and front axle.
ravenhurst
Feb 16, 2010 05:53 PM
stickemdano
Nov 14, 2009 11:13 AM
markrd
May 8, 2009 01:39 PM
