93 W vin starts fine but misses terrible cold or hot idle or W.O.T. !! HELP PLEASE?!
Old Apr 20, 2014 | 09:29 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
put a timing light on it and see what the timming is at...dont forget the by pass wire in the passenger side floor area mines a single brown wire
Old Apr 21, 2014 | 07:47 AM
Muddigger86's Avatar
Muddigger86 is on a distinguished road
Yup already got to it. Thanks. Mines a tan wire with black stripe.
Old Apr 21, 2014 | 02:17 PM
what was the timing at?
Old Apr 21, 2014 | 02:37 PM
gota get a light and I'll let you know.
Old Apr 26, 2014 | 10:00 AM
Distributor changed out old one was rough to spin and reductor was hitting I think also. Bushings out. Now I have no power to coil. Shouldn't I have power to cool with key on. Anyone know why I may not be getting power to cool now??
Old Apr 26, 2014 | 09:34 PM
make sure you have all wires pluged in to the dist and to the coil pack if i member right there are 4 wires
Old Apr 27, 2014 | 02:14 PM
got her back started. had fouled out new plugs from the old distributor and went back to old ones. changing out to new ones today. old ones were hopfully fouled by bad distributor. now that new one is in hoping for the best. the pickup was hitting the reductor in the distributor. thinking that was main problem but cant tell with it in motor. when I took it out the distributor had a catch to it when I would turn the bottom gear and when it would mate up to the reductor. thinking I had a bushing out in it enough to foul some plugs and fouled out new ones also when I changed them the first time. When I get home from work with plugs today. Hoping it will run proper with new plugs and new distrubutor this time. fingers crossed as I am getting to the end of my rope.
Old Apr 29, 2014 | 07:24 AM
well time to look at the knock sensor and/cam position sensors. And maybe even the temp control sensor. I've read where the temp sensor can make it run rich?? IS this so? anyone have a similar problem? and Does the knock sensor retard the timing or does it control the voltage to the coil some how that it could be going out and turning power on and off a lot during while it is running and making it run bad? Its running better just not correct. Just seems like a timing issue. Any help is appreciated. thanks
Old Sep 28, 2015 | 12:04 PM
Default was the spider.
ran rough but was ultimately the spider injector. other things needed but not the main cause. sorry just getting around to updating the thread.
stevenhousden
Jul 6, 2014 05:56 PM
Bill Gillin
Dec 23, 2012 04:56 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
wiblazerman
Mar 21, 2009 06:32 PM
ivannj
Dec 19, 2005 07:54 PM
