94 CMFI Injectors Not Firing
Old Aug 8, 2009 | 11:37 PM
SSZ28's Avatar
SSZ28 is on a distinguished road
Default 94 CMFI Injectors Not Firing
Checked the Shrader valve for Fuel Pressure, Works. Spark, and firing order and timing checked. Car has been sitting for over a year. The injectors will not fire, Checked the power to Spider, w/ BAT ground, and test light works, tested Spider ground to BAT (+) and nothing, it appears that the ECU is not sending the signal for the Spider to operate. Hooking +12v to Spider Positive and temp grounding it, will cause it to work. cranks with starter fluid.
Any suggestions? Aftermarket(new) MSD Coil. Fairely new MSD billet distributor, had to replace the Module for it to spark.
Thanks
Martin13
Nov 15, 2013 07:32 AM
creighta
Jun 12, 2010 02:02 PM
Boise LCD
18
May 24, 2010 11:14 PM
wayland
Dec 9, 2009 12:38 PM
jhuseman
Nov 13, 2006 09:30 PM
