94 help
94 help
well my blazers been out of commission for a while due to its failure to stay running, it would idle all over the place whenever it wanted, randomly stall out, check enginer on and off, so adfter replacing my egr, fuel filter,fuel pressure regulator, plugs wires, cap & rotor,vaccum lines, still wouldnt run right. recently i was under the truck running new vaccum lines and saw that my o2 sensor plug was melted to the begining of the y-pipe, took it off tucked it up away from the exhaust, and what do ya know it was shorting out, truck ran with no check engine light, and a nice idle..sometimes it can be so simple..but now i have a new problem, sometimes when i put the truck in gear it stalls..usually reverse..and especially in 4x4..any help would be great
Did you repair the melted wiring?
yes i did, it seems when ever i fix something something else goes wrong ya know
