-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   94 jimmy (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/94-jimmy-52347/)
Wezo2 Dec 5, 2010 05:01 PM
94 jimmy
Hi I have a 1994 jimmy with a w vin. There seems to be a sound coming from the engine. It sounds like an accordion coming from the globe box area. Also my heater just started only working on defroster and nothing else. Anyone have any ideas?
swartlkk Dec 5, 2010 05:06 PM
A loss of vacuum to the HVAC controls will result in the HVAC system going to default positions which happens to be defrost.
Wezo2 Dec 5, 2010 06:08 PM
Where are the vac lines located?
swartlkk Dec 5, 2010 06:11 PM
They run from the engine, through a check valve, to the vacuum reservoir under the hood, then through the firewall and to the HVAC control module. If you have 4wd, there will also be a 'T' after the check valve to go to the transfer case.
Wezo2 Dec 5, 2010 06:49 PM
Those are the lines that come off the back of the intake manifold correct? The ones just above the distributor?
ohsofly Dec 5, 2010 08:56 PM
yes ,and the resevoir is that black sphere about the size of a 5pin bowling ball.
Wezo2 Dec 6, 2010 12:02 AM
One of my Vac lines came off so I zap strapped it in place so wont pop off again but I still hear a weird noise coming from behind glove box. I think maybe my blower motor is on its way out. The sound sounds like an accordion.
Wezo2 Dec 6, 2010 01:23 AM
ttt please
swartlkk Dec 6, 2010 06:09 AM
Please wait at least 24 hours before bumping your post. Consecutive posting outside of that guideline is against forum rules.
Could you describe the noise in more detail? Have you investigated under the dash to find the source of the noise? If not, it might be a good idea. You could have been doing something constructive instead of uselessly bumping your post at 2AM EST.
Wezo2 Dec 6, 2010 10:34 PM
HAHAHAHA Sorry boss but I live in the west and it was 11 pm when I posted that. My bad anyways back to my Jimmy
When I accelerate there is a noise that sounds like an accordion/air groaning coming from behind the glove box/floor area. It rises with the rpm of the engine and when the trans shifts to the next gear it goes away until the rpm rises again. I had the trans rebuilt less than 3000km ago so I know its not that. Any help boys?
