94 jimmy
Old Dec 7, 2010 | 02:02 AM
Does it sound like it is inside the cab out outside? Possibly your HVAC blower? Can you pin point the noise? The more detail you can provide the better we will be able to help you.
Old Dec 7, 2010 | 10:16 AM
Litehwk356's Avatar
Litehwk356 is on a distinguished road
could be an exhaust leak. the stock exhaust runs right under there.
Old Dec 7, 2010 | 10:25 AM
Kainon's Avatar
Kainon is on a distinguished road
Def only
Noise from behind controls
Sounds to me that the vac hose on the back of the control came off OR the Accordion sound could be the diaphram for the diverter door has a hole
I would get under the dash, locate the diverter door diaphram, remove the hose, start the engine
see if you have any vaccumm to the diverter door diaphram hose
while disconnected the accordian sound should go away, if so then you found your problem.
bdude273
Nov 22, 2013 08:30 PM
Az_S15
Tires and Wheels
Jul 16, 2013 03:29 PM
Dunkshouse
Apr 25, 2013 07:32 PM
LowLife
Jan 24, 2010 11:57 AM
