94 rearend question
Old Mar 22, 2011 | 11:49 PM
j_hiero's Avatar
j_hiero is on a distinguished road
Default 94 rearend question
I have a 94 s10 blazer 4x4 4.3 auto. The other day I was driving down the interstate going 70mph when I felt a big bang and lost all power. I made it off the road. At first I thought it was the tranny but when the tow truck driver called me back he said all 5 wheel studs on the driver side were sheared off.I havent had a chance to pull the rear diff off to see but with the drive shaft out the tranny shifts through all the gears with no problems. If it is the rearend and I find one on craigslist how will I know if it is the same gears?
Old Mar 23, 2011 | 12:18 AM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Old Mar 23, 2011 | 06:26 AM
The gear ratio will not be stamped on the axle housing itself. For that you have to look up the RPO codes (sticker in glove box) and go from there. Being a 1st gen, you likely have a 28-spline 7.625" GM rear axle.
Did the wheel fall off on the driver side? If all you did was sheer the wheel studs, you should be able to get that fixed up for under $30 (studs & new lug nuts). Wheel studs are fairly cheap.
Old Mar 23, 2011 | 10:37 AM
Magmotor's Avatar
Magmotor is on a distinguished road
Your RPO code for the rear axel will either begin with a "G--" or "H--" (more likely a G, mine is GU6 which is a 3.42 Ratio) If you give me your code ( G or H) I can tell you what ratio rear axel you have. If you find a Parts car you can compare the RPO numbers too see if they match.
Old Mar 23, 2011 | 12:02 PM
So, I am going to replace my rear end with any other out of another truck that has the same RPO code in the glove box? I am going to go get my code now, I thought I just had to match the axle code. I am glad I ran into this thread.
Edit: My glove box has these 3 codes... GQ1, GT4, G80
So, how could mine have those 3 codes. look in the glovebox at the RPO codes.
GU2 2:73 ratio
GU4 3: 08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio ----This is my ratio
GT5 4:10 ratio
GQ1 Open Differential Rear Axle ---How could I have this code
G80 Positraction/Locking Rear Axle ---AND this code? I know I have posi cause they do lock. The wheel only spins a little when theyre off the ground and then they both spin.
Last edited by burning_soul07; Mar 23, 2011 at 12:39 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Mar 23, 2011 | 03:50 PM
Magmotor's Avatar
I don't where your getting your info from but here's what mine says:
G80: Axle Positraction, Limited Slip
GT4: Axle Rear, 3.73 Ratio (Dup with 5x1)
GQ1: Axle, STD Ratio
Old Mar 23, 2011 | 06:38 PM
Probably from an unrepitable source from Google. Thanks for the clairifycation. I now know what to search for during my next trip to U- Pull It.
Oh, and the whole reason why I'm changing out my rear is the inner pinion bearing is bad. It has been grinding during deceleration for a few years. I'm still a little shaky about opening something like that up considering the percision that it takes to get it back together.
Dallas1970
Feb 22, 2019 05:05 PM
lt170chevelle
Dec 14, 2009 12:18 PM
DFINE160
Dec 7, 2009 12:17 PM
Lower_Level
Oct 27, 2009 01:04 AM
BlazerLS95
Jan 15, 2005 06:47 PM
