ABS Light On- Multiple codes
Old Aug 30, 2010 | 09:02 PM
ClueMeIn1989's Avatar
ClueMeIn1989 is on a distinguished road
Default ABS Light On- Multiple codes
After replacing my FPR and nut kit, etc.. a couple weeks ago, my ABS light would come on with start up and stay for about 5-10 minutes then shut off and I could feel the ABS reactivate and the light goes off, last night after turning the truck on the "Anti-Lock" light stays on now and won't shut off. I paper-clipped the OBD1 A to H to check my codes and I am getting many different codes. I have 25, 66, 21.. and a couple more. I lost a little brake power for a split second the other day but that was the only time it has physically malfunctioned. Any ideas on what is causing the light to stay on?
Old Aug 31, 2010 | 01:19 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Code 21 - Right front wheel speed sensor or circuit open
Code 25 - Left front wheel speed sensor or circuit open
Code 65 or 66 - Open or shorted pump motor relay
So what are the other codes? Need all the info if you want help fixing it.
Old Aug 31, 2010 | 12:53 PM
ok so I double checked and these three codes are all I'm getting, they just flash three times a piece lol. Do ya think this sounds like an electrical connection issue?
Old Sep 2, 2010 | 12:35 AM
Sounds like you have some sensor issues in the front sensors. You can try cleaning them. That sometimes helps. You mightt also check the wiring from the sensors. Sounds like your OBD is working properly.
jonaflague
Sep 19, 2013 12:13 AM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
