ABS plug
Old Nov 20, 2007 | 10:01 AM
docta J's Avatar
docta J is an unknown quantity at this point
Default ABS plug
i found a plug under my hood that was unplugged. i plugged it in and the abs light on my dash came on. is this suppose to stay on all the time? i would really like to have abs for the winter
thank you
Old Nov 20, 2007 | 10:28 AM
Default RE: ABS plug
If the ABS light is on, it means there is a fault in the system. This could be numerous things from a faulty wheel speed sensor to a fauty ECBM (electronic brake control module).
The previous owner probably disconnected it because they didn't want to see the light.
Old Nov 20, 2007 | 08:50 PM
Hanr3's Avatar
and the light also tells you the ABS system has been deactivated due to the fualt Swart mentioned.
get teh code read and post up.
Old Nov 20, 2007 | 10:55 PM
docta J's Avatar
how do i read the trouble codes? on my other car, i have to turn the key 3 times and then the check engine light blinks. i tried that on the jimmy, but it didnt work. what do i have to do?
Old Nov 20, 2007 | 10:59 PM
cliro's Avatar
cliro is an unknown quantity at this point
go to an autozone and get them to read the codes for you its free, or autovalue if your in canada
Old Nov 20, 2007 | 11:03 PM
docta J's Avatar
thanks
Old Mar 3, 2008 | 08:07 AM
jamon8's Avatar
jamon8 is an unknown quantity at this point
could you post a pic of the terminal that you unplug to get the light to go away
I would appreciate it
Old Mar 3, 2008 | 09:34 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
There is like a four, or five, wire plug on the top of the Control Unit. It supplies power, and such. Unplug it, and the lite will go out. (But, your ABS most certainly will not work.)
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
iamchevyman5
Feb 28, 2011 04:35 PM
stormshadow1
Apr 23, 2009 09:46 AM
boulonman
Mar 5, 2007 05:10 AM
