AC drops battery gauge way down
Old May 2, 2012 | 05:31 PM
richphotos's Avatar
Default AC drops battery gauge way down
Well, I had to use the AC in the jimmy today, its humid and hot, I turned it on, blows nice and cold. but I noticed my battery gauge dropped down. I have the digital dash, and it dropped down to the 5 lines in the solid green area, I would imagine that would be the red area on non digital gauges. it never goes below the 5 lines, it will go back to normal for a shot period, but mostly stays down there. I was thinking maybe my alt cant keep up and is going bad, any other suggestions?
Old May 2, 2012 | 05:47 PM
richphotos's Avatar
Found this photo online just for reference, This is where the battery gauge drops to when the AC is on, never below that point, sometimes will go back to normal, but the battery light never comes on and blinks. I'm confuzzled
Old May 2, 2012 | 06:45 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Has to be a bad connection by your blower motor. Lift the hood and check the area by the firewall and passenger side. There should be a 6? pin wire clip going in to the right of the blower motor, make sure these contacts are clean and also make sure your ground is connected firmly to a clean surface. The ground is on the blower motor itself.
If a loose connection is the issue, it causes the fan to draw more amps.
Old May 2, 2012 | 07:17 PM
richphotos's Avatar
It does not do it when the heat is on, only when the AC is on. I will check that out though
Old May 4, 2012 | 06:56 AM
richphotos's Avatar
Any other ideas? gonna check out a few things this weekend, one being the tensioner pulley
Old May 4, 2012 | 07:46 AM
pettyfog's Avatar
If it stays there, no matter what engine rpm, seriously looks like the alternator or else the connections to it.
If it's only at idle, then what is your rpm at that time?
tensioners a good idea but if you have no belt squeal...
Old May 4, 2012 | 04:29 PM
richphotos's Avatar
I will check the connections to the alt, it stayed around the same when driving, the couple times I saw it go back to normal we were sitting in a fast food drive through.
I have a multi meter, How would I go about testing the alt with it?
And when checking the connections on the alt. Whats the best way to do that, I do not want to short anything out unhooking and checking the connection without doing something else
Thanks knowledge bank pettyfog
Old May 4, 2012 | 07:16 PM
pettyfog's Avatar
Just turn ac on and measure voltage at batt terminals. Should be about 14.5 on cold start @1000 rpm {when alt /engine /radiator warms voltage goes down}
Compare that to that idiot graph display.
If 14.5 not at battery ..
Take it to autozone and have them bench test it. AFTER they run the first test,Tell them what your problem is.
Wincanton
Aug 7, 2015 07:13 AM
BlackBlazerCricket
Jun 4, 2014 12:40 PM
RomanCatholic
Nov 9, 2009 06:14 PM
AEChevy
Jan 20, 2009 10:19 AM
ned4spd8874
Mar 6, 2008 09:40 AM
