Access cut-out for fuel pump?
Old Jun 13, 2011 | 04:18 PM
JerryB52's Avatar
JerryB52 is on a distinguished road
Lightbulb Access cut-out for fuel pump?
Don't be shocked, is it possible to cut a panel out to have access to the fuel pump without dropping the tank?
Has anyone done this?
I put in a new fuel pump and the car ran for one day then the next morning, it died on the way to work and will not start again.
I've really been chasing this problem.
Put in new ignition coil, distributor cap and rotor, thinking that could be the problem. Not...
After a thorough inspection under my plenum, there are no leaks at FPR or nut-kit, (even with key on).
Tried pulling the fuel filter and testing from there to tank but could not get the right fittings to hook up the fuel pressure tester. Fuel pressure at shrader valve about 50 with key on and immediatly falls to zero.
Put in new fuel filter and while the plenum is off, will probably put in a new FPR....
All I can think is that I some how installed the fuel pump wrong. I don't remember if I clamped the little rubber hose that was on the new pump.
Old Jun 13, 2011 | 06:47 PM
rriddle3's Avatar
Has anyone done this?...
A couple of members have done it. The 'search' function should help you find the threads.
Old Jun 13, 2011 | 09:06 PM
abig84's Avatar
yeah this has been discussed a few times. dont blow yourself or the truck up and it makes the job a bit easier
Old Jun 14, 2011 | 09:54 PM
jeepjunky's Avatar
jeepjunky is on a distinguished road
I've done it and love it.. just be careful!
Old Jun 15, 2011 | 04:52 AM
JerryB52's Avatar
It looks like a friend of mine and I are going to drop the tank again.
I'll take my time and make sure it's done correctly this time.
jsgrind
Jul 21, 2014 06:42 AM
seadog1
Jun 2, 2013 11:56 PM
comandoed
Mar 13, 2013 06:56 AM
dubaholic2
Jun 19, 2011 09:06 PM
jcortes63
Nov 3, 2008 11:10 PM
