aftermarket temp gauge decision and install
Old Mar 2, 2010 | 10:38 PM
fruggy's Avatar
fruggy is on a distinguished road
Default aftermarket temp gauge decision and install
Hi Im new here to the forum. I joined and did some searching but couldnt get to the bottom of my question. well I have had my 94 s10 tahoe blazer for about six months and about 3 months ago the temp gauge stopped working. I tried replacing the temp sending unit but didnt help. I am afraid its the gauge. It is the digital dash. So I have been trying to find how to hook up an aftermarket gauge. I have read for a mechanical one there is a nut and bolt on the end but am still confused on where to hook it up. I also read that a digital one you wire it somehow but am just a little confused. I would prefer a mechanical one. like a needle gauge. what gauge do you suggest and how do I hook it up? thank you in advance.
Old Mar 3, 2010 | 01:27 PM
ohsofly's Avatar
Which temp sender did you change? Mine didnt work when i got it, and my sending unit was broken off. The one that sends the signal to the guage is on the passenger side of the engine between and a little above the spark plugs, its gold and takes a 13/16 to undo it. Change it fast cause coolant is going to puke out the hole when you take it out. The one on the thermostat housing is for the ECM input not the guages.
Old Mar 3, 2010 | 01:56 PM
fruggy's Avatar
ohhhh! ya i changed the one that was on the t stat housing. I saw that one you were talking about. It has a wiring going to it if Im correct? Can I just get a new one at auto zone? thank you
Oh and also Im not concerned about coolant coming out. I need to flush it anyways its very dirty.
Last edited by swartlkk; Mar 3, 2010 at 02:44 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
MikeTastic
Feb 11, 2013 03:47 PM
warthogdriver
Aug 11, 2011 08:56 PM
warthogdriver
Aug 5, 2011 06:40 PM
zakm0n
Jan 9, 2011 07:31 PM
rogggg1020
Oct 24, 2008 07:49 PM
