Backup Lights not working
Old May 30, 2007 | 01:40 PM
Shamrock3's Avatar
Shamrock3 is an unknown quantity at this point
Default Backup Lights not working
1985 Blazer, 5 speed manual transmission. Both backup lights not working. Checked bulbs and are good.
Need to find the location of the backup switch and want to start there and see if I have a bad switch or wiring..
Old May 30, 2007 | 02:00 PM
Default RE: Backup Lights not working
Mostlikely is the switch. It should be located on the transmission. I don't have access to my references at the moment and won't until really late tonight. Hopefully someone else can answer you sooner...
*Moved to 1st Gen Tech*
Old May 30, 2007 | 06:24 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Yep the switch is in the side of the transmission..passenger side IIRC, but it has a 2-wire connector. Easy andquick diagnosis, key on, unplug the connector from the switch, install a fused jumper wire across the 2 terminals of the connector, and the lights should turn on. If so the switch is bad.
Old Jun 1, 2007 | 11:57 AM
Shamrock3's Avatar
Jumppered the wires,, and lights came on..Looks like the switch is bad...
Is there and special procedures to replace it, or is it a simple unscrew out and screw new one in.
Should the transmission be in any paticular gear?
Old Jun 1, 2007 | 05:57 PM
lastcoupe's Avatar
Nah, doesn't matter, just unscrew it and screw the new one in. It's a 19mm or 3/4" iirc.
Old Jun 2, 2007 | 06:12 AM
Shamrock3's Avatar
Thanks..
Yes it was the switch. 22mm deep socket. The switch is a round button roller actuation, looks like a ball bearing.
Ah yes, on to state inspection to see what else they can find wrong. LOL
Old Jun 2, 2007 | 05:04 PM
lastcoupe's Avatar
You're very welcome, good luck with the inspection!
Old Jul 16, 2008 | 08:54 PM
drlapp's Avatar
drlapp is an unknown quantity at this point
I have the same problem.I have the new switch but I can't find the old one on the transmission?
Old Jul 18, 2008 | 05:25 AM
drlapp's Avatar
I found it and changed it but still no lights.I checked the fuse.Next I will check the bulbs.
Old Jun 18, 2009 | 02:38 PM
wolf8892's Avatar
wolf8892 is on a distinguished road
Im a noob here.
Any idea where this switch is located on a 1994 s-10 Blazer Auto 4dr?Any help will be greatly appreciated.
