Bad Wheel Bearing??
Old Aug 16, 2009 | 06:20 PM
mikes93s10blazer's Avatar
mikes93s10blazer is on a distinguished road
Question Bad Wheel Bearing??
Hi guys, I got a 93 S10 Blazer with the 4.3 Vortec and 4x4, a few weeks back i noticed a "groan" coming from the front end in left turns and no noise when I turn to the right. Now the darn thing makes this noise in a straight line at about 40mph on up, gets worse when i turn to the left, and stops when I turn to the right. I'm 99% positive its the outter wheel bearing, and to replace that I'll need to get the whole hub assembly. What I'm wondering is, could it be the inner bearing, just behing the hub assembly? Im ok with with buying the new hub, but since I already got it apart "somewhat", would the inner bearing groan like that? I dont really want to get that involved, but if it needs to be done I'll do it. Thanks,
Mikel
Old Aug 16, 2009 | 06:36 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Can you feel play in the hub when you move it back n forth. I'm not sure what you mean by "inner bearing" but the hub assembly is a sealed (non-serviceable) bearing. It is the only bearing outside of the carrier that I'm of aware of in the front end.
Old Aug 16, 2009 | 07:48 PM
SORRY SORRY SORRY, I just looked at it and wiped some of the grease away, its not a bearing. I guess its part of the axle and the seal on the outside egde? I looked up the parts on Pepboys.com and they talk about an inner and outter bearing, and now that I think about it, a second bearing would be pointless. OOPS, MY BAD. So anyways I'm guessing I should just buy a whole new hub assembly? I just dont want buy one, install it and find out it was something else. Like I said before, I'm 99% sure thats the problem, I just want some kind of confirmation.
Last edited by mikes93s10blazer; Aug 16, 2009 at 07:56 PM. Reason: i was confused about what i saw on the truck
yoshiaka13
Jul 20, 2012 08:53 AM
DaveRush
Nov 5, 2011 06:30 AM
TheRandom1
Oct 9, 2011 07:59 PM
ZLover4Life
Jan 19, 2010 10:28 AM
yazan84
Mar 10, 2008 06:53 PM
