Barely runs, no idea.
Old 08-11-2011, 06:31 PM
xul's Avatar
xul
xul is offline
xul is on a distinguished road
Default Barely runs, no idea.
'91 S10 Blazer, 4.1 4x4 @ 234,000~ miles
Issue: I start it, it tries to stay alive, until it dies. does this a lot. backfires here and there.
If I keep trying and keep pumping gas into it, she'll will eventually run flawlessly which is confusing.
Have had this issue for many months. It has only got much worse recently.
have tried: a new fuel filter, air filter, IAC valve, general tune-up
I keep looking around this forum for other ideas, but nothing really seems to working
we're clueless, help please
Old 08-11-2011, 06:34 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
you have a 4.3 not a 4.1.
Remove and clean the egr valve. its behind the throttle body,little black round thing. you need to remove the tbi unit to get it out,clean it with brake cleaner and reinstall.
Old 08-11-2011, 06:47 PM
xul's Avatar
xul
xul is offline
Yes, 4.3, sorry.
I will look into this, thank you.
Old 08-12-2011, 08:19 PM
xul's Avatar
xul
xul is offline
Cleaned it up, no help.
We also cleaned the throttle body a little, but no dice either.
Old 08-12-2011, 11:46 PM
xgiovannix12's Avatar
any codes ?
Old 08-13-2011, 12:46 PM
xul's Avatar
xul
xul is offline
I believe 42 came up;
42 – Bypass or Electronic Spark Timing circuit - The EST signal did not change when the ECM applied bypass voltage to the ignition module.
Old 08-13-2011, 01:00 PM
pettyfog's Avatar
One of the great things I've found in over twenty years of working on EFI systems is that the ECM is in fact the last thing to suspect.
active module then wiring, followed by sensor.
Old 08-13-2011, 03:01 PM
xul's Avatar
xul
xul is offline
This, right?
Also, tried to check for codes again a few times, and only code 12 comes up now.
Old 08-14-2011, 02:09 PM
xul's Avatar
xul
xul is offline
We ended up pulling the gas tank and replacing the Fuel Pump.
She seems to work great now
Old 08-14-2011, 03:34 PM
good to hear thanks for telling us you fixed it =)
Quick Reply: Barely runs, no idea.
