Body lift
Hey ya'll I just got my 3 inch body lift in today went to start installing it and found that finding longer oil cooler lines is alot harder than I thought it would be.
I was wondering where I can find a set or how I can make my own set. Right now the oil lines are the only thing stopping me from getting this done. |
Find a shop that makes hydraulic lines and they'll be able to make up your oil lines no problem.
sweet man I'll see if I can find one
mine were leaking like crazy. i ended up replacing them by cutting off the couplings with a dremel. then used rubber hose (proper grade for high heat fluid) and hose clamps. not glamour or style points, but they've been a perfect solution for my leaky issue. it's up to your standard of crafting and price point. but as the previous comment said, hydraulic shops can do them up for you too.
X2 on making your own. High pressure rubber hose, and use the original fittings. A hydraulic shop would be the best option, but I've had two hose clamps at each end on mine for just over a year, and so far (knock on wood) I haven't had a single drop leak out.
Ok so I have a shop that will make the new oil lines... but since it is an automatic trans (yukKKKK hate it wish it was a 5 speed) I was asked what I am gonna do about the trans lines??? I have tried to google the trans lines but have found nothing.... This is my first body lift... I have done plenty of suspension lifts but don't have the money for one on this rig yet.... anyways again any info would be great
also I would like to know how to find out which transfer case I have.
Originally Posted by 1965Chevy
(Post 623611)
Isn't GU6 just the code for the rear end ratio? The transfer case should be either a NP233 if you have three buttons on your 4x4 switch; if you have four buttons, I believe it's a NP236 case.
Originally Posted by cleburne red
(Post 623989)
| All times are GMT -5. The time now is 10:11 PM. |
