brake Booster question
Old Jul 20, 2014 | 08:06 PM
Davidisme's Avatar
Davidisme is on a distinguished road
Default brake Booster question
I have a question removing the booster seems pretty basic but how do I remove the push rod from the pedal.
Thanks for the help.
David
1994 s-10 blazer
Old Jul 21, 2014 | 08:17 PM
Davidisme's Avatar
I see a small cotter pin where the two connect I assume I am supposed to pull that and it will free up the pushrod. tight quarters that's why Im wondering. Thanks
Old Jul 21, 2014 | 08:27 PM
rexmburns's Avatar
Super Moderator
Correct!
Old Jul 21, 2014 | 08:39 PM
Davidisme's Avatar
thank You, now I know Im on the right track.
Old Jul 24, 2014 | 08:17 PM
Davidisme's Avatar
Default What the flip????
Ok, am I missing something here???? All four bolts on the inside of the cab have been removed I have the push rod off the brake pedal, the two bolts on the booster itself have been removed WHY wont the booster come loose? I have tried pulling it pushing it, love tapping it from the inside of the cab or the back side of the booster, this beast will not budge, am I missing something???? What a PITA.
On the other side of the coin people complain about the upper left bolt in the cab....I used two extensions and a swivel adapter and I was able to get it no problem....of course after getting frustrated over LOL
David
Old Jul 24, 2014 | 08:45 PM
odat's Avatar
just a thot - sometimes during assembely inside the cab there are little paper thin flat washers that thread on the studs to hold everything in place untill nuts are installed
Old Jul 26, 2014 | 02:24 AM
Davidisme's Avatar
ok, thanks bud. tomorrow, it comes out!!!
Old Jul 26, 2014 | 04:09 PM
Davidisme's Avatar
Ok, booster is out new one is in place waiting to be secured in with bolts. Looking at the pedal and this is where I knew I would run into trouble. Can someone give me some direction with how this plate goes back into place. I know that the white and red button have to touch as is evedent by the contact points on the plate, but I cant get it to line up correctly without depressing the white button I believe it is.
Thanks David
Attached Thumbnails brake Booster question-brake-pedal-1.jpg   brake Booster question-brake-pedal-2.jpg
Old Jul 26, 2014 | 09:02 PM
rexazz2's Avatar
if I am seeing right the plate in place should hold down both buttons
The buttons are normally held down until you press the the pedal
Old Jul 27, 2014 | 01:27 AM
odat's Avatar
if i remember right the top hole in the plate goes over the booster rod on the rod pin and the second hole is bolted to the brake pedal - plate lines up to depress both switches at once - one is brake light and the other maybe the cruse control cancel switch
K1500brute
Mar 14, 2012 04:04 PM
whistle
Nov 20, 2006 12:42 PM
consernedguy
Nov 6, 2006 11:19 PM
JCG1
Suspension Tech
Sep 19, 2006 02:07 PM
khalid_20879
Jan 3, 2006 01:00 PM
