Brakelight switch.
Old Dec 19, 2010 | 08:23 PM
bowtie-72's Avatar
bowtie-72 is on a distinguished road
Default Brakelight switch.
Quick question, does anyone know how to pop that clip loose that holds the brake light switch in? I don`t want to tear mine up first to find out.
Old Dec 21, 2010 | 09:09 AM
Kainon's Avatar
Kainon is on a distinguished road
i'm curious, I'm having a problem with a code about my brakes switch with the ABS unit, but the brake lights seem to be working Ok.. why are you replacing your brake switch ?
thanks
Old Dec 21, 2010 | 07:02 PM
bowtie-72's Avatar
Sometimes my lower brake lights will not come on. I have no codes, and my multi-function switch is fine, so the problem has to be in that side of the switch. It IS original!
Old Dec 21, 2010 | 07:44 PM
AJBert's Avatar
If memory serves it is a simple E-clip. A flat tip screwdriver positioned correctly with a simple twist of the wrist will back it off easily.
Old Dec 25, 2010 | 03:30 PM
bowtie-72's Avatar
Thanks, AJBert. I will use a flat screwdriver with confidence the next chance I get!
Old Jun 8, 2011 | 08:44 AM
Barnyard's Avatar
Barnyard is on a distinguished road
I just replaced mine last night. You will need to use a flathead screwdriver to pry up the clip, then slide it over, then off of that pin. It helps to use a tiny one to get inbetween the clip and the pin, then squeeze a larger one in for more leverage. Once you get that clip off (a real pain in the ace) it is quite simple to replace the switch. Just go back in order of what you did to remove it, then get that clip back on. I had to use a screwdriver again to put it back on.
The reason I replaced it was because my brake lights wouldn't light up when braking. Turn Signals, flashers, parking lamps all worked, just no brake lights. I checked the fuses and they were good so I decided after reading the forum to replace the switch. All is well now and I have brake lights again!
95 Blazer 4dr 4wd
Old Oct 4, 2011 | 05:52 PM
marisol's Avatar
marisol is on a distinguished road
Thumbs down brake light fuse
Hi Barnyard or anyone out there
I have a 2001 Chevy S10 Blazer 4wd in pretty good shape at 120K. My brake lights are out--changed bulbs--still no lights --went to check fuses--the manual and the key legend on the fuse box panel have no brake light fuse listed--nothing! So does anyone know which fuse actually is the brake light fuse? I have the drivers side fuse panel and the under hood fuse box--no mention of brake lights on either--all the other lights but no brake lights. I have checked the fuses with battery tester and all are good--but i may have missed one. I am desperate--I've already been pulled over and given an inspection ticket.
I also have a new switch ready to replace old but cannot figure out that clip holding the old one on.
Thanks,
marisol
Old Oct 4, 2011 | 06:04 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Marisol If you look under your hood in that fuses box on the bottem right if you facing the truck there will be 2 relays and between those two relay will be a row of three fuses and the one in the middle is your right head light are the one to your admedate left is your left head light I had one that was just dim and the fuses didnt look blown from the top but when I pulled it out it was blown but not enuff to completely stop the current
Old Oct 4, 2011 | 06:16 PM
Old Oct 5, 2011 | 08:54 AM
marisol's Avatar
Default marisol-- brake light fuse
Hi Daddysblazer,
Thank you for that --I will keep that in mind--however my problem is finding the brake light fuse-not the headlights. My top brake light is working --the right and left brake lights are out--bulbs are new--just cannot find a blown fuse --but no fuse is marked as the brake light fuse on my manuel key to fuses. Do you know which one is my brake light fuse? Thanks!
