can i use these two together w/o probs
http://www.stylinconcepts.com/parts....tfamilyid/1476
http://www.truckperformance.com/prod...10+Blazer/4.3L
im thinking about buying both of those...there woldnt be a prob if i use them both right?
RE: can i use these two together w/o probs
Nope, it says with the air filter lid.. Fits Models With Round Factory Filter Only (TBI)
right, but the FIPK for the 91 is a round filter, it looks like the same thing except is more open then the factory........ one which one would be better if i just bought one
The first one would probably allow more air flow.
I would get the OEM replacement filter, that has enough air flow. Your engine does have the TBI unit and the computer may not be able to handle the air coming from the air lid. The TBI is designed to with a closed lid for a reason if you remove the metal area directly above the TBI it will affect air flow into the TBI and cause problems. That EXTREME Lid is designed for a large bore carburated engine not a stock V6.
arite thx...wuddya think about a throttle body spacer
What does a TB space do anyways. What do you benifit from it?
cochran07
03-07-2011 04:36 PM
JeremyNYR
04-11-2010 10:45 PM
putting tranny together, lost the spot i was in, now i dont know how it goes back together!!!!!!!!!!
rob1621
03-09-2008 09:39 AM
