cant seem to get it right
Old Jun 20, 2008 | 06:00 PM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default cant seem to get it right
i have been trying for an while to get this freakin oil leak to stop i narowed it down to the valve covers ( well just one them) the that is leaking is the one on the passenger side i have gotten new gaskets on it and the damn thing still leaks what should i do ( v8 conversion is on hold due to lack of funds) i seriously need advice from any skilled person thanks guys
Old Jun 20, 2008 | 06:30 PM
Default RE: cant seem to get it right
How tight are you tightening down the valve cover bolts?
Old Jun 20, 2008 | 09:38 PM
well im tighting them almost till i cant turn the bolt anymore
Old Jun 20, 2008 | 10:21 PM
The Slacker's Avatar
The Slacker is an unknown quantity at this point
way way way too much. just enough to compress the gasket. the torque spec is something very low. like 10 ft pounds. i don't have a haynes manual, maybe someone else does. make sure sure all the bolts line up. if you're having troubles keeping it in place, dab some RTV gasket maker on the gasket and let it tack up so the gasket sticks to the valve cover. then put it on.
Old Jun 21, 2008 | 04:29 AM
Definitely way too much.
If you have center bolt valve covers (which I think you do, but please put your vehicle information in your signature), then the torque required for the bolts is 106 inlbs (or pretty close to 10 ftlbs as The Slacker stated). That is just barely snug with a 1/4" ratchet.
Basically, by over tightening the bolts, you are squeezing the gasket out, causing the leaks.
Old Jun 21, 2008 | 08:06 PM
alright well i guess im off to get another gasket and try it that way thanks guys
Maxboost25psi
24
Feb 13, 2013 02:20 PM
nellymerc
Dec 26, 2012 04:37 PM
01LtBlAzEr
May 25, 2012 10:31 PM
Kai
Jan 9, 2012 10:46 PM
A-Rak
Jun 22, 2011 10:36 AM
