code 13 wont go away
Old Dec 24, 2010 | 11:02 PM
jimmybob's Avatar
jimmybob is on a distinguished road
Default code 13 wont go away
This place is awsome ,wish I had found it sooner .
I have a 92 s15 Jimmy 4x4 with the Vortec 4.3. The o2 code 13 keeps coming on and off when driving .I have replaced the o2 sensor twice with no change .All the wires seem to be in good shape .Was getting codes 43 for knock sensor and code 44 lean burn .Replaced the knock sensor and got rid of that code ,but once in awhile still get a lean burn code ???
It only sets codes when driving down the road .I have checked the FPR and it isnt leaking ,fuel press,is running 60# not running and 54# running ,checked base timing ,new plugs ,new map sensor ,and tps .
When sitting at idle it smells like its burning rich and the dang thing only gets 10 MPG
Any suggestions ???
Old Dec 27, 2010 | 01:12 AM
jimmybob's Avatar
no takers ??
Old Dec 27, 2010 | 06:23 AM
Have you checked the wire from the O2 sensor to the ECU (Pin D7 purple wire) with a multimeter set to the resistance scale? How about the ECU O2 sensor ground (Pin D6 tan wire)? The ground is only at the ECU so test the resistance to ground.
Old Dec 27, 2010 | 11:15 PM
jimmybob's Avatar
Hadnt done any thing like that yet ,not sure how to ??
Do I need to unhook the wires to do this and hook the prob up to one wire nd the other prob end to the other ??
Old Dec 28, 2010 | 08:03 PM
jimmybob's Avatar
probe wires found the problem
when I changed the o2 sensor some grease got in te plug .sprayed the heck out of it with contact cleaner and so far its good to go
Old Dec 28, 2010 | 08:18 PM
Glad you found the problem!
Zombie
Jun 24, 2013 08:51 AM
Klturi421
Aug 25, 2012 09:30 PM
KevinZR2
Mar 22, 2012 06:34 PM
jman_08
Oct 2, 2008 02:20 PM
the fuel
Engine & Internal
Jan 16, 2006 12:27 PM
