Code 21
Old Oct 13, 2013 | 07:56 AM
gdhurst's Avatar
gdhurst is on a distinguished road
Default Code 21
After I accessed the codes and replaced the coolant temp sensor my blazer became slow to start. (Before it fired right up every time, now it takes a little cranking). When it does start it idles fast then slow then the check engine light comes on and it runs fine but the light stays on. I checked it and it coded 21 meaning TPS voltage low? I have a mind to buy a new sensor as this truck sat for a little while before I bought it. Will this solve the issue? it is only a 50 dollar part. Also I want to clean the MAP Sensor can someone explain how to do this? Maybe the injectors as well? I put seafoam in the tank once already and am thinking about it again to clean out the system.
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
