Code 34 problem
Old Jun 24, 2009 | 11:34 PM
19884x4blazer's Avatar
19884x4blazer is on a distinguished road
Default Code 34 problem
I am getting a code 34 for the map sensor voltage low. I have checked the wires at the sensor and at the computer. There isn't any problem with wires in either place. Is there any other wires that I need to check or find?
Old Jun 26, 2009 | 09:49 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
replace the MAP and see what happens.
Old Jun 27, 2009 | 04:03 AM
the map sensor tested good
Old Jun 27, 2009 | 04:22 AM
95POSmoneypit's Avatar
95POSmoneypit is on a distinguished road
Is your truck running erratically? Try cleaning the contacts between the wire and the sensor? Maybe a lil electrical grease? That would be my first attempt...
Old Jun 27, 2009 | 02:06 PM
Have you checked the wiring between the MAP sensor and the ECU?
Old Jun 27, 2009 | 03:20 PM
yes, i have and I am still getting a weak signal
Old Jun 27, 2009 | 08:03 PM
What is the voltage being sent to the MAP sensor from the ECU? It should be +5V if I remember correctly. If this varies at all during operation, you either have a wiring problem or an ECU problem.
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
