code 42
Old Jan 11, 2013 | 08:18 PM
blueblazer1969's Avatar
blueblazer1969 is on a distinguished road
Default code 42
i have a check engine light on and it is a code 42 i was told that it is the distributer pick up.it stalls when you stop and i was told that is a symptom of a bad pick up.going down the road its fine but as soon as you come to a stop it will die .my question is how difficult is this to replace ? and do i have to pull the distributer to replace it?
Old Jan 11, 2013 | 08:20 PM
chris015's Avatar
its either the :
Pick up coil
Ignition module
i bet its the module. they are more common then the pickups. make sure u stick with ac delco brand on these parts.
Old Jan 11, 2013 | 08:30 PM
xgiovannix12's Avatar
Its most likely the module. This is the way to diagnose it.
Ill retake the picture if you cant read it..
I have a Tested ac delco module for sale if your interested. You can get yours tested at your local auto parts too.
Old Jan 11, 2013 | 09:07 PM
i have replaced the module with an ac delco module .where is the pick up located at? do i have to remove the distributer to replace it?
Old Jan 11, 2013 | 09:42 PM
it should be right under the ICM
Old May 7, 2013 | 04:16 PM
Skitzoape's Avatar
Skitzoape is on a distinguished road
what manual is this dude? i NEED it lol
Old May 7, 2013 | 04:52 PM
The manuals the dealers use . they can be found via ebay for great prices if you wait long enough
Old May 7, 2013 | 06:04 PM
Skitzoape's Avatar
yea i found a few... $70-85 thought. is it well worth the money? seems it if it tells you how to troubleshoot stuff in detial as it does above
Old May 7, 2013 | 07:09 PM
its very worth it... I payed 25 for my s10 one and I think 30 for my fullsize truck one
Edit: here is a picture of them
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
