died when stopping, wont stay on...
Old Jul 24, 2010 | 11:08 PM
mrnewtona's Avatar
mrnewtona is on a distinguished road
Default died when stopping, wont stay on...
Hello all. I have a '93 s-10 and I am having big issues right now. I just drove from California to Utah, and along the way noticed a tiny crack in the radiator. I purchased some Bar's Leak Liquid Aluminum Cooling System Stop Leak and put about half the bottle in and the leak stopped. Now today, while I was coming to a stop at a red light, the truck started idling really rough and died. I got it to start again and moved it off the road, but as soon as i took my foot off the gas, it died again. It won't run without being revved. The engine is making a pretty loud "thub-thub-thub" noise while it is running. I replaced the fuel pump relay switch about two months ago because it got fried. Any ideas or suggestions as to what is causing the problem?
Old Jul 24, 2010 | 11:44 PM
drtyblnd's Avatar
drtyblnd is an unknown quantity at this point
how hot did you get it ?
Old Jul 25, 2010 | 02:14 AM
mrnewtona's Avatar
The temp never ran over 200. I had stopped and noticed that it was leaking and hissing, so I immediately went to Napa and got that liquid aluminum. The engine ran fine the whole drive to Utah. As for it dying today, the temp got up to its normal 200. I had been driving for about 10 minutes btw...
Old Jul 25, 2010 | 08:41 AM
You need to do some diagnosis and let us know the results. Just to name a few things...
Check the plugs - they can show you if the cylinders are burning proper or not.
Check the fuel pressure (and leak down) - your engine needs 55+psi to run properly and it shouldn't drop more than 5psi after the pump shuts off.
zstudna
Oct 15, 2012 07:19 PM
chazsblackbravada
Feb 19, 2011 09:43 PM
95s10
Jan 21, 2011 10:08 AM
chazsblackbravada
Jun 28, 2010 11:31 PM
n.kognitoh
Jun 14, 2010 01:22 PM
