Drives side widow came off regulator
Old Jul 26, 2011 | 04:59 PM
FreaKariDunk's Avatar
FreaKariDunk is on a distinguished road
Default Drives side widow came off regulator
Ok. So, It came off, so that means I will need the clips, but I have a regulator question (it is electric).
The arm works along with the motor, so I have the glass up (its been raining and its propped up. So, How do I put it together? Does the arm slide into the metal bit at the bottom? Does anyone have any links to pictures, how would I go about putting it back together?
Thanks
Old Jul 30, 2011 | 08:48 AM
summit high's Avatar
summit high is on a distinguished road
i dont have pics BUT ... i done this before on mine .
the arm from the regulator goes in the track attached to the bottom of the window .
i have had to replace the motor on a few of my windows so i have just took the pannel off , drilled out the rivets and replaced the motor . just a side note , if you ever have to do this BE CAREFUL !!!! THE REGULATOR IS SPRING LOADED AND LIKES TO HURT YOUR FINGERS !! check your roller on the arm to ensure its not wore out
(mine was ,and had to get a new regulator)
Old Jul 31, 2011 | 11:00 AM
Default a follow up
Is there a way to take the actually metal door off, i got the handle and the foam off. but i didnt see a way to do that. So i can get to the regulator and motor better.
Thanks
Old Aug 3, 2011 | 10:32 PM
sorry, been really busy ,
the regulator , motor assembly is riveted onto the door !
in order to remove it, you must drill out the rivets !
then you can slide the arm out of the track integrated into the bottom of the window
you will want some 1/4 " bolts to replace the rivets (stubby) and i recomend some nylock nuts , so they dont back out on you .
once you remove the rivets be ready to catch the window through the bottom and grab the regulator/motor ***. with the other hand
oh ya the track is attached to the bottom of the glass in a semi permanent fashion , so taking it off , is not recomended !!! (unless you know what your doing )
88s10Blazer
Sep 11, 2013 02:41 PM
Dweeberman
Sep 23, 2011 12:47 AM
trailblazin88
Apr 18, 2011 08:15 PM
Wexinlo
Apr 6, 2011 11:35 PM
Blazin_1t_up
Sep 29, 2008 02:18 PM
