Egr
Old Nov 25, 2010 | 08:22 AM
seanpconley's Avatar
seanpconley is on a distinguished road
Default Egr
94 s-10 W Over the summer I replaced the FPR, Plugs, wires, nut kit and got another spider from a junk yard cuz I broke mine. Lately the car IDLES like crap and hesitates on acceleration. I should of replaced the distributor parts when I was in there but at a quick glance they looked fine.. If I unplug the EGR what can I expect to happen any other ideas why my ride is stumbling I mean it gets me from point a-b heat works a/c works and I get like 17 mpg could it be exhaust related also ??? Oh I should add that the plug wire that goes to the ICM is rusty but I assume works because it won't start if I unhook it
Old Nov 25, 2010 | 08:53 AM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
fuel filter maybe. check all your connections, plug wires, etc. What your fuel pressure?
Old Nov 25, 2010 | 12:43 PM
I should of sated that it is a fairly new gas tank and fuel pump. I haven't checked the pressure and will can you think of anything else if that is good. I am actually at work yeah I know it's thanksgiving but what if I go and unplug the egr will I beable to tell if it's bad based on what the engine does?
Old Nov 25, 2010 | 09:54 PM
shawncullen's Avatar
shawncullen is on a distinguished road
unplugging it wont help
its really easy to take it off and see if its clogged by
a hunk of carbon though
Old Nov 26, 2010 | 04:55 AM
94BlazerPA's Avatar
so when you replaced the pump and tank, did you replace the filter?
Old Nov 27, 2010 | 07:40 PM
yes I did replace the filter twice.....because the new gas tank came from a junk yard.....I need to check for codes but I also need to replace the wire to ignition control module it's pretty rusty inside of it near the dist cap ..blazerpa where abouts in pa are u I live in NEPA?
Old Nov 27, 2010 | 10:12 PM
94BlazerPA's Avatar
yeah it could be a bad connection
I'm down in Philadelphia
Old Nov 30, 2010 | 05:15 PM
I'm in wilkes-barre anyway I took out the egr and cleaned it today!! changed the dist and rotor while under the plenum also.... I swapped that bad wire out for another one from a junk yard looked good to me? decided at night to look under the hood and I saw sparks and heard popping at the ICM this can't be normal eh? that surely would cause the car to run like hell IMO
Old Nov 30, 2010 | 06:08 PM
94BlazerPA's Avatar
yeah seeing sparks isnt good. I havent had to mess with my ICM, so I cant help you at what would be causing the sparks.
Old Nov 30, 2010 | 09:02 PM
I stand corrected the part that is popping is the actual coil not the ICM.. I really hope this takes care of my sluggish ride the wires and plugs were done in the summer so prolly not them I don't know anyone think a bad coil although always starts would make it run kindda crappy?
