EGR delete?
Old Nov 23, 2020 | 07:48 AM
Strickland's Avatar
Strickland is on a distinguished road
Default EGR delete?
I have a 1993 GMC Jimmy with the 4.3 Vin W CPI engine. My problem is the EGR. If I delete the EGR, will I have a continuous check engine light? Is there a EGR block off plate available for it? The Cat is gone. Also, has anyone had problems with their distributor? I'm at 230K on the clock.
This is my first thread here.
Old Nov 23, 2020 | 07:33 PM
LesMyer's Avatar
We don't discuss removing emissions equipment on road-riven vehicles.
Old Nov 24, 2020 | 07:49 AM
Strickland's Avatar
Thumbs up
I found a neat trick. use a spark plug boot (90) with the guts pulled out to replace the 90 degree rubber EVAP hose connection to the throttle body.
Old Feb 14, 2021 | 11:42 AM
Strickland's Avatar
Default W engine problem
More problems with my Jimmy. It starts and runs well for about 10-15 minutes then shuts off. Just for grins, I replaced the spark plugs, no change. Checked the fuel pump pressure and got 53 psi. Could this problem be caused by the change over from open loop to closed loop?
Old Feb 15, 2021 | 02:10 AM
I'm going to close this thread as you have opened a new one for this specific problem.
Driftedcraft
Oct 18, 2019 11:40 AM
bam_9_9_9
Oct 7, 2012 11:31 AM
wiblazerman
Feb 19, 2010 08:59 AM
95rRED4x4
Feb 10, 2007 02:04 AM
2klt
Feb 20, 2006 02:29 PM
