egr valve clean
Old Mar 13, 2013 | 10:08 PM
clicheche's Avatar
clicheche is on a distinguished road
Default egr valve clean
what exactly are the symptoms of a 'dirty' egr valve? i 'cleaned mine out today' with throttle body cleaner. i've heard mention of soaking them over night. is the screen on the gasket overly beneficial?
any feedback would be sweet.
ps: it was removed with 10mm socket. used extension on driver side bolt. only have to detach air hose and corresponding wires.
Old Mar 13, 2013 | 10:09 PM
clicheche's Avatar
'94 T10 with a cpi engine.
Old Mar 16, 2013 | 12:58 AM
ohsofly's Avatar
Symptoms - code 32 or 34 (cant remember which) in the engine light... Stalling out at lights and easily restarting... surging at operating temperature.
Old Mar 24, 2013 | 10:34 PM
cleburne red's Avatar
A stuck open egr is basically a huge vacuum leak. Horrible idle, poor acceleration, but drive-able at speed. The screened gasket is a must!!!! Chunks of carbon from the intake is what sticks in them and holds the little plunger open. If you go back with a regular gasket, you will more than likely have the same problem again very soon.
Old Apr 2, 2013 | 02:28 AM
GMC_Jimmy_13's Avatar
GMC_Jimmy_13 is on a distinguished road
If an EGR valve was stuck open would it make a loud annoying noise?
Old Apr 2, 2013 | 07:15 AM
I'm not sure you would be able to hear it, but it would be very noticeable from the way the engine would be running, in my experience.
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
bryan101
Sep 14, 2010 12:31 AM
Crestwood1001
May 17, 2009 01:07 PM
Brocktward
Apr 8, 2008 09:12 PM
riverjamie
Sep 25, 2007 08:32 PM
