Electric 4WD not engaging on 94 Blazer
Old Sep 19, 2011 | 11:40 AM
94fireblazer's Avatar
94fireblazer is on a distinguished road
Default Electric 4WD not engaging on 94 Blazer
The other day i switched my Blazer into 4 High with the electric switch to climb a small hill and cut my truck off after disengaging 4WD. Later that day i tried to put my it into 4 High and got nothing, the lights didn't flash at all and didn't feel it engage. I put it into neutral and tried and got 3 simultaneous flashing from both high and low then nothing. Anyone have any tips on where to start or had the same problem? Thanks!
Old Sep 19, 2011 | 05:54 PM
Magmotor's Avatar
Magmotor is on a distinguished road
First thing I'd do is check for codes, A & J. I'm sure you have some, then ,the next thing I'd do is "clear the codes". If you don't know how, yell, it's quite involved. The Encoder switch is fickle on these units. Sometimes it forgets where it's at and gets quite confussed....lol....did the same thing on mine and worked great...no problem switching back and forth now.
Old Oct 1, 2011 | 10:44 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
transfer case encoder motor. its an electric motor that shifts the t-case into 4x4 had the same problem. push 4hi and the lights would just blink. try putting it in nutral and pushing 4lo and if it engages then its the encoder motor. they run pretty cheap at junkyards but a brand new one is costly. but on mine i had a hard time getting it to go back into 2hi when in 4lo cause the motor was weak.
Old Oct 6, 2011 | 09:58 PM
Johnnyboy's Avatar
Johnnyboy is an unknown quantity at this point
Had the same problem. As Magmotor says the Encoder Switch might forget what position it's in. Try his fix first. Unfortunately it's not a servicable Part if it is bad. My Codes kept showing an Encoder problem. Mine turned out to be the Transfer Motor. They are not as expensive as they used to be. When mine went a friend of mine was working for a Chevy Dealer & his price was $450.00 at that time. I went a couple years without 4 wheel drive until I found a new one on E-Bay for $168.00 & I haven't had a problem since. Money well spent I thought. That was about 6 years ago. Not hard to replace either. Good Luck.
Old Oct 8, 2011 | 07:13 AM
harley745's Avatar
harley745 is an unknown quantity at this point
most of the time its the vacuum accuater under the battery
seriosbrad
Nov 7, 2015 09:08 PM
toyblazervt
Nov 28, 2010 05:07 PM
chrisblaze
Dec 6, 2009 12:27 AM
Doverman454
Nov 29, 2008 01:45 PM
punx.inc
Dec 25, 2007 12:07 AM
