electric 4x4 not working
Old Jan 30, 2010 | 02:36 PM
lakahahahman's Avatar
lakahahahman is on a distinguished road
1992 blazer has push button 4x4
was working 20 minutes ago then i went to push it again and nothing no clicks in dash like before
when i turn key on the light on the switch go on then off
all i did was work on the stereo then nothing for 4x4
i checked the 5amp fuse in box labeled tccm and it is ok
so just to say again i start truck and push 4x4 button nothing at all happens no lights flash no clicking in dash no nothing
any ideas would be greatly appreciated
thank you Henry
ok so i messed around with the 4x4 some more
now when i put the truck in nuetral it is auto
then i can push the button it will go into low range but not high range
it will not even try to go to high range unless i put the truck in nuetral
lights will not flash until i shift to nuetral
Last edited by rriddle3; Jan 30, 2010 at 05:16 PM. Reason: MERGING CONSECUTIVE POSTS
Old Feb 2, 2010 | 04:21 PM
1992blkblazer's Avatar
1992blkblazer is on a distinguished road
Default no 4x4
man sounds like your having the same issue as I am. i disconnected the battery for about 30 min and that reset the tccm ( which is located on the pass. side under the dash ) went into 4 wheel high fine but when turned the car off went back to the same problem. I'm thinking the relays in the tccm are bad but if you have fixed your issue please let me know what the problem was hope this help you a little bit
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
toyblazervt
Nov 28, 2010 05:07 PM
218persuader
Aug 20, 2010 06:11 PM
punx.inc
Dec 25, 2007 12:07 AM
