Electric window Stopped! HELP
Old Dec 19, 2006 | 01:02 AM
SDimeBlazerlady's Avatar
SDimeBlazerlady is an unknown quantity at this point
Default Electric window Stopped! HELP
Driverside window stopped on me! its cold n i need my Truck!!! its a 87..Im broke no job so i need to at least put window up any idea's that dont cost? lol
Old Dec 19, 2006 | 01:04 AM
hillbillyinOhio's Avatar
Default RE: Electric window Stopped! HELP
might have just came off track. pull interior door panel off and see if everything is plugged in and the motor puts the arm up and down.
Old Dec 19, 2006 | 01:12 AM
rooster's Avatar
rooster is an unknown quantity at this point
sometimes it simply just the switch. which u can find in the HELP section of any parts store.can u hear the motor and arm moving.the worse case would be the motor went. they are spring loaded so be careful, but u may have to drill out some rivots. and the new motor should have the 3 sets of nuts/bolts to replace the rivots. either way in the meantime u can wedge up the window by taking off the two blots that hold the window to the slider and placing a piece of wood under the window. u know enough to keep the window up.
Old Dec 19, 2006 | 10:02 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
I got my window motor off ebay for 25 bucks shipped with a lifetime warranty, its very easy to replace it.
Old Dec 19, 2006 | 02:21 PM
Thank u all for your help n idea's its fixed for the moment lol
Old Dec 19, 2006 | 02:25 PM
Chevy Lover's Avatar
How did you fix it for the moment?
Old Dec 20, 2006 | 06:15 PM
SY_98Blazer's Avatar
SY_98Blazer is an unknown quantity at this point
Can anyone give me an idea of how complicated it is to remove and replace the motor? Its "spring loaded"... Do I need any special tools?
Thanks
Old Dec 21, 2006 | 12:57 AM
Maybe this post from the "DIY" section will help.
https://blazerforum.com/m_23879/tm.htm
Old Dec 21, 2006 | 01:05 AM
rooster's Avatar
not really, just a socket for the replacement bolts/nuts. the arm when installed needs to be held in place. the "spring load" is more like a tensioner in the motor so the arm will want to swing back!
jayfire
Jan 20, 2012 12:16 AM
toyblazervt
Nov 28, 2010 05:07 PM
Dudleys Blaze
22
Mar 2, 2010 11:03 PM
jman382us
Feb 3, 2010 06:47 PM
punx.inc
Dec 25, 2007 12:07 AM
