engine cleaning
Old Dec 6, 2006 | 05:08 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default engine cleaning
anyone know a fast and easy way to clean the engine
Old Dec 6, 2006 | 05:12 PM
Default RE: engine cleaning
I use simple green and a hose. Just be careful not to get a solid stream onto the alternator. I usually take a plastic grocery bag and cover the alternator.
Old Dec 6, 2006 | 05:16 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Lol I knew it, that is why my alternator died! I thought that was the reason, but people didnt think so. A day after I degreased and washed my engine down the alternator slowly started to die. Until it was officially dead and my battery died and I got stuck on a random road due to this.
Old Dec 6, 2006 | 05:30 PM
emgoodyear's Avatar
emgoodyear is an unknown quantity at this point
Carquest sells a purple cleaner that works well.
Old Dec 6, 2006 | 05:43 PM
Yeah the alternator can be damaged by lots of water. Everything else should be fine. Of course, if you disconnect the battery and then allow everything to thoroughly dry before reconnecting it, you shouldn't have any problem either.
Old Dec 6, 2006 | 06:51 PM
FImports's Avatar
thanks
Old Dec 6, 2006 | 08:01 PM
FImports's Avatar
can i find simple green anywhere.so just spray leave it on for how long.then rinse with water.how do i get that shine
Old Dec 6, 2006 | 08:10 PM
Well you can probably get it at any autoparts store. Just spray it on and leave it on for 5-15 minutes with the engine slightly warm. Be sure to cover your altenator from getting wet, I found this out the hard way. Then just spray it down. If its really dirty use a big plastic fiber type brush that would typically be used for tires or somthing and use that.
Old Dec 6, 2006 | 09:03 PM
Yeah, depending on how dirty your engine is, you may need to scrub, leave it sit, rinse and repeat until you have it the way you want it. You can buy Simple Green pretty much anywhere. Last time I bought it I grabbed a gallon jug of the concentrate and I don't think I'm 1/3 of the way through it yet. And I use it for everything from engine cleaning to putting in with my dirty shop rags.
big armo
May 12, 2011 11:43 PM
matt92
Jan 11, 2011 09:43 PM
Bullfrog2099
Sep 26, 2010 08:47 PM
burak sozer
Jun 9, 2008 03:17 PM
a_tack
Detailing
15
Feb 24, 2007 11:26 PM
