engine coolant sensor
Old Mar 11, 2013 | 08:39 AM
drummerdude's Avatar
drummerdude is on a distinguished road
Exclamation engine coolant sensor
I recently had my 94 S10 blazer's check engine light come on. After reading the code, I get a code 14 which indicates there is a bad temp. sensor. My issue is previously I have replaced the sensor on the pass side between the plus when I had a gauge reading problem. I now read that there are 2 sensors. Where is the 2nd one located? Also when looking on Autozone, I only find 1 sensor, do they use the same sensor? I seem the remember the one on the side only had 1 wire going to it, but all the sensors I find are 2 wire.
Old Mar 11, 2013 | 09:46 AM
mr.vls's Avatar
The 2nd sensor is near the water inlet at the front of the intake manifold. It is not the same sensor.
Old Mar 12, 2013 | 02:19 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
The sensor that the computer uses to calculate coolant temperature is the one next to the water inlet on the top of the manifold. That's the one you need to change. The other sensor, the one in the passenger side cylinder head, is just a simple thermal resistor to run the dash gauge.
Old Mar 16, 2013 | 01:02 AM
ohsofly's Avatar
One is a "Coolant temp sensor" - the one you need
The other is a "Temp sending unit" - the one you changed.
jcw7897
Feb 6, 2015 06:23 AM
AcerDeucerQ
Dec 3, 2012 06:29 AM
ab2008
Jul 10, 2012 05:16 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
N.alaska_blazer
Feb 23, 2009 01:31 PM
