engine dies when hotabad doesn t start anymore
Hi everyone,
My engine dies when hot and doesn t start right after, but when it gets cold again then it starts...
What do you think it can be, or does anyone already got this trouble???
Need help as soon as possible... please...
Thanks
Thanks
are you low on coolant and is your thermostat working right? That is probably where I would start checking.
Also, vehicle information might be helpful.
I wonder what you're driving?
Does your oil dipstick smell like gasoline or oil?
And what are you driving? Are you getting a check engine light? If you get a light straighten into a U shape and jam a paperclip into the top 2 right holes on your OBD port down by your knees and see what codes the engine light flashes at you when you turn on the key after putting in the paperclip.
Can try electronic spark control module. Mine would run fine then just die.
sounds like your starter solenoid getting hot and sticking.
Try beating on it while some one starts the vehicle.
Sorry guys, I am driving a 4.3 Vortec...
We also need year, and model.
Blazers had the 4.3 V6 in them since the late 80's, and the 4.3 was also ran in other GM vehicles.
My 95 has trouble starting when it's hot.. doesn't die though. Sometimes it isn't getting enough fuel (new pump, gonna change the filter tomorrow), sometimes it sounds like the battery is dead but I had it checked and it's fine. Starter gave strange readings though.
