Erratic idle
Old Oct 30, 2010 | 08:00 PM
cjcustoms's Avatar
cjcustoms is on a distinguished road
Exclamation Erratic idle
I have a 1986 S-10 Blazer that has an erratic idle. It gets so bad that you have to pretty much stand on the brakes to keep it stopped at an intersection. I started looking at possible problems and stumbled across one that baffles me. When it's in park or neutral, everything is fine. Once it's in reverse or drive it surges to a real high idle. The weird thing is that when it's in neutral, I can ease the shifter each way without letting it engage into a gear and the idle raises and lowers. Is the neutral safety switch somehow tied into the idle circuitry? I need some help here, what else can I check?
Old Oct 30, 2010 | 08:15 PM
The idle speed is controlled by the ECU via the IAC sensor in the side of the throttle body, but it is only controlled when in park, neutral, or the throttle is closed. What may be happening in your case is that the TPS sensor could be not returning to what the ECU is expecting for closed throttle and causing the condition.
Old Oct 31, 2010 | 10:00 PM
bowtie-72's Avatar
bowtie-72 is on a distinguished road
Maybe try cleaning the throttle body/TPS.
Old Nov 2, 2010 | 05:41 PM
seanpconley's Avatar
seanpconley is on a distinguished road
it's definitely the TPS or too much Carbon in the throttle body
gunner0352
Feb 20, 2010 11:51 PM
ralsmack
Nov 4, 2009 03:59 PM
Nicholas_29
Aug 23, 2009 09:47 PM
Biohazed
Aug 16, 2009 12:52 AM
disturbedgame
May 2, 2007 09:18 PM
