Freeze Plugs in 4.3L
Old Jan 8, 2008 | 08:59 PM
GuyFromWI's Avatar
GuyFromWI is an unknown quantity at this point
Default Freeze Plugs in 4.3L
Hey, I am leaking anti-freeze and I am wondering how many freeze plugs there are. I believe this is where the leak is coming from and hoping I don't have to take out the engine to replace the plugs... Thanks!
Pete
Old Jan 8, 2008 | 09:07 PM
Default RE: Freeze Plugs in 4.3L
There are 2 on each side of the block and two on the front of the block. On the older blocks, there may also be a freeze plug in the back of the engine in the bellhousing area. Run a search for "freeze AND plug" and you should come across some helpful information.
Here is an article that shows the differences in the engine designs:
http://www.babcox.com/editorial/ar/ar39840.htm
The block pictures show the ones on the front and sides of the engine.
Old Jan 8, 2008 | 09:11 PM
GuyFromWI's Avatar
Ok, I seen four and wondering if there were anymore. I looked at your other posts about freeze plugs and wondering if there were more then that...
Old Jan 9, 2008 | 07:27 AM
As I have stated, of the freeze plugs that are accessible from the outside, you have 2 in the front (off either side of the water pump - see the picture in the link I posted) and two on each side (the front ones will be under the engine mounts). The 96+ engines do not have the two freeze plugs on the front of the block.
I do not believe there were ever any rear freeze plugs on these engines, but I also cannot find a good picture to tell for sure. If you aren't having any coolant leaking issues within the bell housing at the back of the engine, don't worry about it.
Tortex53
Dec 27, 2010 06:11 AM
dashyman
Dec 15, 2008 04:28 PM
ShadowHawk
Dec 15, 2008 04:27 PM
smokincivic98
Apr 10, 2008 07:26 PM
Bigjoey71
Engine & Internal
Dec 23, 2005 03:45 PM
