fuel pressure regulator
Old Feb 20, 2013 | 07:33 PM
holyman1973's Avatar
holyman1973 is on a distinguished road
So I reconnected the fuel line and testing pressure at the plenum koeo i am reading 49 psi and 40 psi after 10 minutes. I have not removed the plenum to watch form leaks. I know this pressure is not spec. Should i remove the plenum and perform the same test koeo?
Old Feb 20, 2013 | 08:49 PM
Regulated pressure is too low, which means the fuel pressure regulator is set too low, or defective. You can remove the plenum, activate the pump, and check for leaks. As I mentioned earlier, regulator adjustment is not recommeded. If there are no leaks, replace the regulator.
Old Feb 21, 2013 | 07:29 PM
Against what you advised I adjusted the regulator and got the pressure up to 60 psi koeo. No leaks, no puddling of fuel and pressure dropped to 54 psi after ten minutes. I will put the plenum back on tomorrow and see what happens. If the regulator fails you warned me. I gotten pretty quick at pulling the plenum apart.
Old Mar 12, 2013 | 06:40 PM
clicheche's Avatar
clicheche is on a distinguished road
following closely. great job the two of you! sorry about the gas in the face. not good.
Terje
Nov 4, 2017 08:19 AM
vifa84
Jul 7, 2007 01:58 PM
jr9880
Feb 8, 2006 07:08 AM
jlinder
Aug 21, 2005 11:08 AM
