-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Fuel Pump Died. (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/fuel-pump-died-77267/)
mr.vls Feb 15, 2013 03:09 PM
Fuel Pump Died.
Today my 89 GMC Jimmy died on the interstate going up an overpass. Luckily I was able to coast up and down the bridge and was able to pull off to the side of the interstate. I poured a small amount of gas directly into the TBI and the engine fired right up so I knew it was most likely the fuel pump. I called AAA for a tow to my independent mechanic. The current pump was installed in 04 and has lasted for around 100K miles. Right now I am recovering from rotator cuff surgery and I am not able to do any mechanicl work for at least 4 to 6 months. Hopefully, I do not have any other major vehical problems happen while I am sidelined.
chris015 Feb 15, 2013 03:46 PM
sucks that happened. have him check the relay before replacing the pump. Also,tell him to order the pump from the dealership. you'll be glad u did.
ohsofly Feb 15, 2013 08:35 PM
Yup. Use a delco pump. Anything else is just junk.
richphotos Feb 15, 2013 11:02 PM
rock...auto.... delphi or delco. I used delphi, and only have used delphi, have had great luck with them. the price at rock auto is amazing, I am not sure about showing up at a shop with the part already telling them to put it in, however.
mr.vls Feb 16, 2013 05:35 AM
The shop is going to use delpi.
chris015 Feb 16, 2013 07:12 AM
good nuff! delphi ftw. good luck with it. Replace the relay with it for added insurance.
richphotos Feb 16, 2013 10:07 AM
MAKE SURE YOU LOOK AT THE PUMP TO MAKE SURE ITS A DELPHI!!!
Shops have been known to say they are going to put in the better pump, and get a cheap one and charge you for the better one.
mr.vls Feb 18, 2013 02:14 PM
My fuel sending unit was errattic at near the full mark so I was intersted in getting a complety new fuel assembly. The shop called me today and said that they could not get the delphi unit at a good price so I asked if I could supply them the assembly and they said no problem. So I ordered the Delphi HP 10020 from Amazon and paid a little extra for next day delivery. I should have the pump on Tuesday and the shop should have it on Wenesday. I previously installed a spectra sending unit and was not really happy with it. This is an opportunity to install OEM equipment.
richphotos Feb 19, 2013 11:35 AM
Good choice, and awesome that the shop will put in the part you supply, they usually do not do that.
Spectra= fail in these trucks
chris015 Feb 19, 2013 05:54 PM
they'll do it,but it voids any warranty on parts. Now if that new pump dies your paying them to do it again. i learned that the hard way.
