Fuel Pump Relay Clarification needed
i have a 94 s-10 blazer that will not start and i am trying to narrow it down...
fuel pump relays are in the firewall directly in front of the steering wheel in the engine bay.... there are 2 relays that are identical to each other... one clicks when i turn on the key and the fuel pump goes on and off and the other does nothing... why are there 2 relays.... do they both need to be clicking...??
if i swap them, the fuel pump does not come on at all when i turn on the key... flip them back and the fuel pump comes on..but the car still will not start.
do they both need to be clicking.... 10 bucks each is better than 120 for the fuel pump and parts.... and 5 hours to drop a tank and swap a fuel pump (that comes on even though i am only getting 20-50 PSI fuel pressure with ignition on....
car wont start...
please help
thanks
car wont start...
please help
thanks
replaced both of them.... and it still wont start... back to the guess work...
man i hope someone has had this problem before and tells me what they did to fix it...
i havent had too many replies on this forum, but on the s-10 forum i have had 5 replies...
i hope this isnt because i am new, i certainly wouldnt do that if you came to my Maverick Forum
thanks for any help
thanks for any help
more and more troubleshooting is leading my to the back end of the truck..... i ahev replaced quite a few fuel pumps....but all the others have always just not worked... this one is coming on and giving fuel pressure, thats why i havent replaced it yet....
my instincts are screaming fuel pump..... my experience is saying that its not it....
if i go and replace the fuel pump and it isnt it.... i will be so pissed... just like anyone else that has spent money and not fix a problem...
yeah... dropped the tank again,.,..the wire pulled out of the top of the sending unit...i had to cut the plastic part away a little bit and solder the wire back together...and then i lengthened the ground wires by about 8 inches....so they wont have tension again... and i also dfound out that the tank was pinching the fuel lines, so i went and bought a new 100psi fuel line and a 3/8 fuel line and re routed all the hoses so they wont get pinched...
everything works great.....
Tony H
Apr 16, 2014 08:36 PM
vaportrail
Aug 25, 2009 09:49 PM
upblazer95
Mar 8, 2009 07:15 PM
mytruck2
Dec 13, 2006 04:50 PM
