Ground wire location?
Old May 13, 2011 | 01:05 PM
JerryB52's Avatar
JerryB52 is on a distinguished road
Unhappy Ground wire location?
On my way to work this morning, my 94 Blazer just died and would not start back up?
No spitting or sputtering, just running fine one minute and then it died.
It cranks over ????
A friend said it may be the ground wire? Does anyone know where this is located on the vehicle?
Someone also suggested the fuel pump?
Any ideas would be helpful to me. Thanks.
Old May 13, 2011 | 08:22 PM
abig84's Avatar
if the ground wire fell off it would crank at all. or very slowly due to one of the smaller grounds staying intact. could be one of a hundred things
Old May 13, 2011 | 10:07 PM
Benedict1337's Avatar
sounds like something with your fuel system if its cranking. does your radio and lights still work? usually a bad ground or a loose terminal will power up all your lights and stereo but when you go to crank it everything shuts off. but that doesn't really seem like your problem
Old May 13, 2011 | 11:12 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
To answer your original question he ground wire bolts to the lower block on the right side in front. You should be able to see it.
Old May 14, 2011 | 04:30 AM
JerryB52's Avatar
I didn't really think it would be the ground wire. Just the easiest to check and or fix...
Going to check the the fuel pump this morning.
Then check ignition spark etc...
Old May 16, 2011 | 11:34 PM
Good idea. If yoru have fuel pressure (55 lbs. +) I would then suspect the ignition module inside the distributor. You can get them tested free at most A/P stores. Make sure they test it several times though.
Survivor
Mar 13, 2020 04:38 PM
eljorgin
May 21, 2019 10:04 PM
Dug44
Nov 29, 2012 06:24 AM
rdhack
Jun 7, 2009 03:38 PM
cide
May 1, 2009 01:07 PM
