Help
Old Sep 10, 2012 | 05:29 PM
n3ls0n90's Avatar
n3ls0n90 is on a distinguished road
Question Help
OK I have a 1989 Chevy blazer 4.3L 4x4 I have recently bought. I've been having some fuel related issues I believe. It seems to be flooding itself out almost while running at idle after I drive it for a bit. Also gets horrible MPG. I originally thought it was a misfire so did plugs, wires, cap, and rotor. This didn't fase it so I changed distributer and compression tested all cylinders and used a bore scope to check for any damage to bore hole or piston head. Any ideas what else it could be. Only thing I can think is injectors or the TB itself. MIL comes on intermittently but even when its on I show no Dtcs.
Old Sep 11, 2012 | 03:49 PM
workshop4ever's Avatar
workshop4ever is an unknown quantity at this point
Could also be the fuel regulator. If it is stuck you could be seeing some high pressures in the injectors, leading to rich mixtures and crappy mileage.
You are certainly correct about the other possibilities as well, could easily be something like a leaking injector/nut-kit. I would rent/borrow a fuel pressure test-kit and do a leak-down test. Then go from there.
Old Sep 11, 2012 | 05:50 PM
n3ls0n90's Avatar
I have a FP set just haven't got around to checking any of it yet lol. Injectors are 100 bucks a piece and that's with a 43% discount lol all the other things it could be are less than 20 bucks. I finally got some flash codes out of it. A 22 and a 43. Any idea there.
Old Sep 11, 2012 | 05:52 PM
chris015's Avatar
Check your other thread,and ive got a extra set of injectors if your interested.
Old Sep 11, 2012 | 05:54 PM
n3ls0n90's Avatar
I may very well be. Ill be in touch if it ends up being the injectors. What u want for them. Might
Old Sep 11, 2012 | 09:24 PM
ohsofly's Avatar
You can see the spray pattern at idle from the tbi injectors. It should look hazy like the road on a hot day does. If you see drips instead, the injectors junk.
Old Sep 11, 2012 | 09:37 PM
Rottidog's Avatar
https://blazerforum.com/forum/genera...34/help-73661/
https://blazerforum.com/forum/1st-ge...40/help-73660/
Do you see a difference? I don't see a difference... There's no difference!
Old Sep 11, 2012 | 09:48 PM
rexmburns's Avatar
Super Moderator
X2 to you sir!! Good find rotti. OP please all to have your posts combined so all the info its in one spot!!
Old Sep 11, 2012 | 09:55 PM
Rottidog's Avatar
I mentioned getting one post deleted in General because he had it posted properly in here, 1st Gen.
