Help with 94
Does anyone have a thoughts on why my 1994 would run rough after warm-up? EGR is fine. It acts as tho its detting to much fuel. TBI, its been a long time since i have turned wrenches and am lost on the next step. I dont want to just start replacing sensors. I got the blazer from a freind and it had sat there for a few years after he got it out of a shop that tuned it up. all he did was the occasional start up to keep fluilds going through the engine. any help would be appreciated.
thanks in advacne |
not sure if its relevant or not but also the temp guage is not working either
The temp gauge not working will tell the computer your engine is cold , like putting the choke on . check the temperature sender on the passenger side of the engine . I think its a purple wire not sure though . Mine the wire melted against the exhaust the first time and the second time it was the temp sender .
ok, one on the side then whats the on next to the thermostat housing with 2 wires?
After doing some reading I guess one works the gauge and the other goes to the ecm , I just read another post on here where drummerdude had the same problem he changed the one thats next to the thermostat housing and the truck ran better he said , but the gauge still didn't work . But anyway the anwer to your question is that one sends temp to ecm .
you have a vortec right ? the 94s had vortecs in them
Im confused cause you said it had a tbi also give me the 8th digit of your vin it will tell me what motor you have Edit: If you have a vortec and the 8th digit of your vins W this sensor location map is right if you dont have this motor ill get you the right sensor map http://i1130.photobucket.com/albums/...2/PICT1461.jpg And here is the diagnosis for the temp gauge http://i1130.photobucket.com/albums/...2/PICT1463.jpg |
