Help a newbie - just bought 93 Blazer
Old Sep 16, 2009 | 11:00 AM
94gmcjimmy's Avatar
94gmcjimmy is on a distinguished road
If you have power locks the switch will be located right next to the manual lock. If it is not working then the fuse is the most likely problem. As for an owners manual you should be able to find one in pdf form online. Sometimes you can get lucky and find a hard copy on ebay. While checking that fuse I would suggest checking the rest incase any others are blown. Remember to keep spares onhand for that fuse that are of the appropriate amperage. If it blew once it may blow again.
Old Sep 16, 2009 | 12:07 PM
old skool luvr's Avatar
yeah that hillbilly method will work too, HAHAHAHA! yes the ABS and 4WD selector systems are tied together (GM had a recall for my '92 Jimmy 'cause the ABS wouldn't always work in 4HI). you never replied to g_mike's question if your truck had the Auto 4WD system or not?
Old Sep 17, 2009 | 05:49 PM
rastoma's Avatar
rastoma is on a distinguished road
Originally Posted by g_mike
does it have 4hi, 4LO 4 auto and 2hi? mine has 4 buttons.
if its not doing anything pop the switch out and check to make sure it is plugged in. you may have to remove the dash frams that goes around the deck, dash cluster and some other switches (good time to put in a aftermarket deck and sub rca cables for your system you are about to buy jkz)
I thought the switch was 4wd/2wd because the markings are worn off. But there is only 1 switch and it's 4hi/4lo.
Also if you you didn't notice I made a mistake on the year above. I had 2003 on my brain because of a Town and Country that I'm working on too. My S10 Blazer is a 1993 not 2003, automatic with vortec engine.
Old Sep 17, 2009 | 09:09 PM
rastoma's Avatar
I thought that recall covered the '93 s10 blazer too but GM said it doesn't.
Old Sep 18, 2009 | 10:15 AM
1 year, in the same model, makes a big difference. look at the '91 Cavalier's, new body style/new car, but built with the same s**ty brakes as the previous generation. it wasn't upgraded 'til '92 (i guess after they realized how they screwed up on that one).
Old Sep 19, 2009 | 04:07 PM
rastoma's Avatar
But the recall lists my year, 1993, but somehow GM says MY 1993 wasn't recalled.
Old Sep 20, 2009 | 11:57 PM
could be your truck was built after the recall date? this happens all the time. the dumb asses higher up, realize something isn't right, and figure out that it was between this day and that day. well, if your truck was built the day before, or after, it's not affected (so they think/say).
you mentioned that the wheels "locked up" on you, are the tires the correct "factory" size? are they really worn out? 'cause the ABS works off of a predetermined tire diameter, and, if the tires are worn out, or have been swapped out for another size, the computer will not be able to interpret this variance as wheel lock up until it's aready happening.
look at the sticker inside the door jamb of your truck (this will have the factory issue tire size for your truck). this is very important, 'cause not all Blazer's/Jimmy's have the same tire size. what is important to remember is that the computer needs the same tire diameter, to fuction properly. so a tire can be wider than stock, so long as the sidewall is compensated for. the wider the tire, the lower the profile, to achive the same O/A tire diameter.
Old Sep 21, 2009 | 06:08 PM
jayjen1317's Avatar
jayjen1317 is on a distinguished road
go to a parking lot drive up to the curb and stop(don't try to get a rolling start) in 2wd try to drive up the curb, your back wheels will probaly spin and it will be hard to go over the curb.
Now back up, put it in 4x4, drive back up to the curb and try to drive up the curb it should go up the curb pretty easily in 4x4.
just because the light doesnt come on doesnt mean that its not working the light bulb could just be out.
Also the reason I said to back up is, some times it helps to engage the 4x4 if you roll a little bit.
spaceapex
32
Jan 18, 2010 09:08 PM
mgout
Nov 6, 2009 10:43 AM
paulzr2
May 22, 2009 02:53 PM
camaro91boy
Feb 8, 2009 11:37 PM
muleman
Sep 28, 2007 02:07 PM
