Help please
Old Mar 5, 2008 | 08:29 AM
badwrench's Avatar
badwrench is an unknown quantity at this point
Default Help please
1985 S10 Blazer
2.5 Standard trans.
4,000 miles on rebuilt engine
Engine starts up fine, at 1st at higher RPMs as normal
Shortly later it idles down
Takes off OK as you shift to 3rd and sometimes as late as 4th gear the engine just stubles
push gas to floor no help
let up and it will try to run
dwn shift andengine still no power.
NEW PARTS
TPS
O2 Sensor
MAP Sensor[/align]Coolant Sensor
Fuel pump and sock
Fuel pump
Fuel Pump relay
Distributor cap and Rotor
Plugs and plug wires
Carb. changed out from a different 2.5 that was runing ok
Coil changed out from a " " "" " " "
Votage input and output checked and OK on:
TPS
Map
O2
Alternator voltage is 15
EGR working OK
Field Service Mode--shows to be in closed loop
No check engine light after start up
No codes stored in ECM
Timing 8degreesat idle after warm up--shows advancement
Fuel pressure of 11 PSI with engine runing
Today I am going to check the wiring to the ECM and make sure the various signals are reaching itbut I'm sure they are because if you disconnect the TPA, or MAP or O2 sensor you will get a check engine light and a code. Going to also checkforpossible vacuum leak.[/align][/align]If anyone can think of what else I can check please let me know. I've tried a local garage and was soaked for$300. for troubleshooting only to be told it MAY be a fuel problem.I've about had it!! Im begin to thank a gal of gas and a match might be the answer but then again gas cost too much.This is my Grandsons car I got for him and put the new engine and also painted. If I don't solve the problem soon I am going to find a different intake and put and standard carburator and distributor in it. Agin thanks for reading and any help you may have.
[/align]
Old Mar 5, 2008 | 07:50 PM
x33camaro's Avatar
x33camaro is an unknown quantity at this point
Default RE: Help please
When you rebuilt the motor did you get a new distributor? How many miles are on it?I am wondering if its failing at higher RPM's?Does the ECM have the heat sink gel on the bottom of it? Just throwing that out there.
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
