help warms up then dies
Old May 29, 2009 | 11:58 PM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
has the TPS been calibrated? some have to be to function properly. google to find answers.
Old May 30, 2009 | 06:57 AM
Biohazed's Avatar
definatly check your fuel pressure first, let us know what the pressure is and we can go from there
Old May 30, 2009 | 08:36 AM
oisinirish's Avatar
Is it possible that the knock sensor has failed and is retarding your timing to eliminate the "knock" to the point that the truck wont run?
Old May 30, 2009 | 09:11 AM
madmike's Avatar
madmike is on a distinguished road
that would do it ....that or the ignition module...
Old May 30, 2009 | 11:30 AM
rriddle3's Avatar
dgh91,
I have combined your three threads on this problem so people can see what all has been suggested and tried. It is best to keep things in one thread for clarity's sake.
Old May 30, 2009 | 02:14 PM
dgh91's Avatar
dgh91 is on a distinguished road
but it only does it when it warms up
Old May 30, 2009 | 02:22 PM
oisinirish's Avatar
Typically, from I've seen suggested, most electrical components fail more readily at operating temp. I've it suggested many times that the component in question should be loaded and tested several times to recreate operating temp during normal operation. Now i'm not sure if a knock sensor is "testable" but I DO know the ignition module is.
Old May 30, 2009 | 03:36 PM
dgh91's Avatar
how do i test the ignition module?
Old May 30, 2009 | 03:40 PM
oisinirish's Avatar
try this on for size. Click.
I was not aware it could be done without special testing equipment.
Old May 30, 2009 | 11:07 PM
dgh91's Avatar
im gunna test the fuel pressure i know it should be between 55 and 61 should it stay the same when the truck is running
