High Idle at Startup
Old Oct 28, 2007 | 09:33 PM
Brandon31386's Avatar
Brandon31386 is an unknown quantity at this point
Default High Idle at Startup
I have a 92 S10 blazer with the 4.3 non vortec engine. When i start it up, the idle is very high. And it shouldnt be that high. And ideas on what it could be??
Old Oct 28, 2007 | 09:57 PM
rriddle3's Avatar
Default RE: High Idle at Startup
If it's a 4.3L V6, it's a Vortec. How high is 'very high'? When does the idle speed drop down?
Old Oct 29, 2007 | 06:28 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
ORIGINAL: rriddle3
Its not only vortecs in 1992, he has the z code TBI 4.3, and yes the idle is high when its cold, like around 2k rpms. Mine does the same thing and I wasted money changing things and it doesnt help.
Old Oct 29, 2007 | 11:16 AM
I could have sworn I posted here... Anyway, the 'vortec' head design came about in the mid-80's. It wasn't until the early 90's when it became a marketing buzz word.
Anyway, back to the problem at hand. I guess we need a quantification to the term 'idles very high'. At what RPM does it idle at when cold. Does it drop down to a normal idle after it is warmed up? If it does, what is the idle RPM warmed up?
Old Oct 29, 2007 | 07:28 PM
ORIGINAL: swartlkk
I think it was 87ish when the "vortec" design came about, but I also believe that you need a different intake to fit that vortec design or atleast that the way it was with a 90 degree SBC V8.
Old Oct 29, 2007 | 07:36 PM
Again, do not confuse the change in the intake manifold bolt orientation with the start of the vortec cylinder head design. All 4.3L engines utilized vortec cylinder heads. Not that Wikipedia is a be-all and end-all source for accurate information, but they have it right in this case: GM Vortec Engine
Old Oct 29, 2007 | 08:42 PM
Its not a Vortec...and i cannot tell what the RPM is because there is no tach. someone told me its either a sensor or a vacuum leak around the throttle body.
Old Oct 29, 2007 | 09:05 PM
You are not listening, but what do I know...[&o]
Anyway, the TBI motors do have a problem with the throttle body base gasket. You can troubleshoot vacuum leaks by spraying some carb cleaner around the base of the throttle body.
Does the idle ever return to normal?
Old Oct 29, 2007 | 10:11 PM
sometimes it returns to normal on its own, sometimes it wont return to normal until i start driving.
and i always thought the vortec engine was the one with the intake manifold and fuel injected. im not too educated on my truck, ive been slacking
Old Oct 30, 2007 | 06:26 AM
ORIGINAL: Brandon31386
Let it warm up, it should drop on its own, atleast thats the way my 92 is.
Kyle, thats something I didnt know I thought the two went hand in hand.
mcdevin1973
Oct 5, 2014 02:52 PM
Denominator
Jul 14, 2009 05:10 PM
chestere
Aug 3, 2007 08:42 PM
swartlkk
Nov 15, 2006 01:46 PM
blazinloud
Engine & Internal
Oct 17, 2006 05:39 PM
